[OFFICIAL] AMD Radeon RX 7900 XTX/XT Owner's Club
5 reading
1.5M views 9.1K replies 566 participants last post by  kokos1948
#1 ·
I figured since people are getting these cards there needs to be a place that discusses the cards itself. Without having to shift through posts regarding everything else. Above you will see all the AIB models and what they boost to. So that should be one question out the way.
#13 ·
Tiachi
Aorus Elite
Nitro
Are all top tier 7900xtx cards out there on air right now. I have not found any review for them yet though. As I want to see what kind of performance they will offer past their boost clocks.
yeah but didn't the TUF and MERC319 both hit 3Ghz?
#9 ·
I wish I could find one to purchase. :(
#11 ·
The stock cooler is something to behold! :cool:
Weighty for sure...
Those fans...
Anndd that backplate 🤓
It's nerd porn... for sure ...
I've owned Tri-X Hawaii, Vapour-X Hawaii, Tri-X Fury, Fury X, RX Vega 64 Limited Edition, RX 6800 XT Pulse...
But this...
I feel like sacrilege will be committed, when waterblock it...
#14 ·
Powerplay table exist but the driver does not use them unless they are signed by AMD so basically encrypted.
#18 ·
I scored 32K in TS. Not bad considering stock for me was 28.3K.
#23 ·
Hold up a second... Can anyone with a 7900 xt/xtx able to check the vbios and confirm if they are on A0 silicon? From the reports these MBA's are A0. I read that GPUz reads the board version not the silicon version? Didn't know that...And not sure how true that is. Can anyone else confirm this?
I loaded up some techpowerup bios and all of them are A0 stepping. Are you sure the A1 stepping is even out there yet?
#24 ·
Well last night initial install went smooth.
i) Used DDU to remove drivers.
ii) Drained loop, removed my RX 6800 XT Pulse with Bykski block.
iii) Rig POSTed 1st time no issue.
In OS Task Manager showed ~8.x seconds bios time, same as RX 6800 XT.
Ran SuperPosition 4K Optimised, got 20K @ stock.
Tried 3DM FS rig black screen and turn off.
Re-powered rig, same thing occurred
Turned off PSU, card is clearly seated well, can see clearly PCI-E seated as it should be. Check power cables, again seated as should be. Using a Cooler Master V850 PSU, separate cables per PCI-E plug.
Ran SuperPosition 4K Optimised, got 22K @ stock.
Tried Heaven rig black screen and turn off.
Tried Witcher 3 rig black screen and turn off.
OS is fresh install only week or two ago, W10 Pro fully updated. OS is not stripped, but no bloat and excess in background from my apps I use or at startup.
Currently on UEFI 4303 Beta for Crosshair VIII Dark Hero, had no issues prior to swapping to RX 7900 XTX MBA.
Trying another UEFI for mobo.
My system specs:-
5800X3D (BR 2422 PGS)
ASUS ROG Crosshair VIII Dark Hero (UEFI 4303 Beta AGESA 1.2.0.8)
Crucial Ballistix Sport LT 2x16GB (BLS2K16G4D32AESB)
SN770 2TB NVMe
2x 870 EVO 4TB SATA
Cooler Master V850
Be Quiet Dark Base Pro 900, front door removed and mesh mod done, top panel stock mesh had plastic removed to improve airflow.
Cooling:-
Bykski A-Ryzen-ThV2-X CPU block (Arctic Cooling MX-4)
Bykski A-SP6800-X Water block (Arctic Silver 5)
2x Magicool 360 Slim G2 radiator
EK-XRES 140 Revo D5 PWM
EK ZMT (OD 5/8", ID 3/8")
Barrow fittings
Coolant Mayhems XT-1 clear concentrate ~20% mix with distilled water
Top radiator as exhaust, 3x Arctic Cooling F12 PWM (push only)
Front rad as intake, 6x Arctic Cooling F12 PWM (push/pull only)
Case rear fan, Be Quiet Silent Wings 3 1000RPM (set to 100%)
Case RAM fan Be Quiet Silent Wings 3 1000RPM (set to 100%)
#26 · (Edited)
Yeah.
Just did last release UEFI instead of latest beta on mobo, UEFI 4201 AGESA 1.2.0.7, same symptoms :(.
Have removed card again and reseated.
All seems fine on PCI-E fingers, slot, etc. Inspecting card visually I can't say it looks as it has any physical issue.
So far only things I can run:-
i) SuperPosition
ii) CB15 OpenGL bench
iii RealBench benchmark
Trying an even older UEFI next, UEFI 4006. I can't go any older as 5800X3D won't be supported.
Only options left are:-
i) Apply an image of OS when freshly installed with no drivers/apps, etc and go from there.
ii) Swap the 5800X3D for 5900X, try even older UEFI on mobo.
iii) Rebuild rig with C7HWIFI
or...
Just sit back and wait for update on UEFI of mobo/drivers on GPU....
** edit **
UEFI 4201 I can't even run Superposition now, black screen and rig turn off...
If 4006 do the same, it's defo mobo UEFI and only UEFI 4303 beta is remotely allowing any GPU usage...
#39 · (Edited)
Was about -2/3C yesterday here in the UK when got delivery. Left it ~2.5hrs inside box in my home, did some unboxing photos for myself, then left it out of box for ~1.5hrs.
Below spoiler screen grabs of install OS wise.
1st screen grab was RX 6880 XT bios time, as had read some stating long POST time on another forum with RX 7900 series, so noted that. Then you'll see DDU, then I drain loop and fit etc...
Looking at driver install screenie time ~4.5hrs time between receiving and driver install.
That Spam supply for the holidays..
LOL!
I was hoping for meaty goodness from RX 7900 XTX, but so far limited :whelp: ...
** edit **
Below attached is memtestcl as txt, change extension to rar. The Stilt sorted it back in 2021 when I asked him as it wouldn't test more than 4GB an instance, if anyone uses please share how it went for you, just be aware you can't really test full VRAM as some will be in use, so set 1 or 2 GB less.
Power draw max ~450W AC wall plug my total rig inc screen.
Original git repo, doesn't do more than 4GB an instance.
#37 ·
oh they only got XT :D
then I guess they hide it as soon as its sold?
#47 · (Edited)
Good to see an owners thread.
I wonder if the 7900xt could be flashed to xtx...is the physical ram there like the xtx I wonder. Just a wondering mind :)
Nah, some chips are taken out/missing physically from what I saw/heard
I guess you can see here
The bottom right memories and probably something more is not there
#50 ·
Anyone with a 7900 XT | XTX and a LG C9 OLED? Could you test if Freesync works? This is a known issue with RDNA 2 where Freesync over HDMI 2.1 (4K / 120hz) won't work and only G-sync compatibility is provided at 4K 120hz (Nvidia cards only).
What I am referring to: Betrieb LG OLED C9 mit AMD-Grafikkarte / HDMI 2.1 und FreeSync / VRR
I‘ll get my card by tomorrow and will report back but as far as I know the C9 doesn’t have Freesync, instead it has a standard VRR implementation that actually worked on my 6950XT (only with the latest few drivers though).
#49 · (Edited)
Video is my rig with all tweaks as I would have on RX 6800 XT, but RX 7900 XTX stock.
Seeing sustained load of ~560W and max ~570W.
Rig has not turned off, where as other GPU loads as stated before do, insta.
I reckon PSU is fine, letting it run with CPU/GPU fah and 400 iteriations of two instances MemtestCL 11264MB.
@kairi_zeroblade
Tried all devices to gen 3 and still issue :( ....
** edit **
15min in now, still max ~570W, sustained ~555W at the time of screenie...
#54 ·
Not running RX7900, but similarly power hungry and easily triggering transient card that would recently cause some weird issues with PC shuts downs.
It would run blender, superposition, realbench, even my Forensic Passware kit with network agents which forces both, GPU and CPU to its knees, but as soon I would start heaven or furmark it would instantly shut down.
If it helps anyone, I have custom cables that I have never had issue with, but for some reason after switching to stock seasonic 24pin all shut downs went away, in fact my whole systems seem to run nicer. I was thinking maybe org. seasonic 24pin has voltage regulator, but didn't look like it, at least from what I could tell, but anyways....how related is that to some of your suts downs I don't know, but I though I would put that out.
#56 ·
I have a C9 I can try.
Reactions: Slaughtahouse
#57 ·
Are the reference editions (power limited by AMD) the only variants that have a USB-C connector?
I... actually don't need three HDMI ports.
#59 · (Edited)
I have fixed my card!!!!! :):):):):)
Stock vs 2600 2400 -50mV, link to same load case. -50mV knocked whopping 138mV on average, wall plug meter now sustained ~440w vs ~555W.
1st runs of 3DM FS TS on new profile/ever on this card for me!!!!
Looking at Guru3d TS graphics score card is benching as should for current drivers, etc...
* edit *
SP4K 23K
