Hey all,
I just tore down my loop to prep the system for Mayhems Pastel... however I discovered the tubing & res has been stained inside with some sort of powdery residue.
The system was extensively cleaned with distilled + isoprop and warm water before bringing it up. I tore down the CPU block as well. Rads were flushed until water was pretty much clear coming out 2-3 times.
I ran the system for 1-2 weeks with the EK ZMT tubing, then tore it down, flushed the rads, and gentle risked my blocks with distilled before putting it back together with Mayhems Ultra Clear tubing.
Ran that tubing for about 3 weeks, then when I tore it down today this is what I discovered...
The white ring around the ends of the tubing is from my compression fittings..
It rubs off semi-easily with my fingers on the Res, tubing seems to rub off if I jam my finger in there as well..
