Problem : Upon pressing the ON button nothing happens.
System details :-
CPU : 3960x
Motherboard : Asus Rampage IV Extreme
Graphics card : 3 x 7970 at 1150/1600
PSU : EVGA Supernova Nex 1500
Case : Cooler Master Cosmos 2
Recent changes & problem details :-
- Moving the whole rig from the old apartment to the new one.
- While moving the rig the 3 7970s have been removed not to apply additional pressure on the motherboard while moving the rig.
- After the moving process is finished the cards have been installed back in and a system boot were successful.
- Been using the system for a day (or two) with no problems (With several normal reboots without any problems)
The day after that at the morning when i came back from college , I powered on the PSU (The PSU LED/LEDs became on along with the motherboard rear LED/LEDs) then i pressed the System's Power ON button (On the COSMOS 2 Case) and there was absolutely no response that is including no psu fan sound and no case fan sounds.
Before i switch on the System i touched the PSUs metal handle (Silver handle in the picture) i noticed that it some how has some sort of a strong (non human leathal) electrical charge that kept on for a while (I did not care about it at first thinking that the problem is somewhere else).
After a while searching i found alot of responses they all state removing stuff and installing stuff and then none of it working.
Trials :-
Any way , What i tried was that i disconnected the psu power cable from the wall's outlet and also disconnect the rest of the computer components from the power outlet as well also removed the LAN cable, and i kept touching that psu handle while touching the ground thinking that i am grounding (removing electric charge from it to the ground) it.
i repeated the process few times until i felt no charge in it at all , and then did it few more times , then waited for the night and tried this morning.
But it did not work.
End.
I am open for suggestion.
But please be smart (Easier solutions first then harder ones).
Ty for your time.
System details :-
CPU : 3960x
Trials :-
End.
Ty for your time.
